that's a bit confusing for me to understand, I guess I'm basically trying to figure out what the biggest size tire is i can get on there after the Frankenlift including the new arms.
I would like a 245/75/17 (Keeping the Stock Rims), but cannot figure out if they will rub & if i would need to re-gear, because i really can't afford that, and i don't think i would want to put the money into that regardless.
the stock tire i have now, 235/65/17 is about 29.5" and to put the money into the lift kit to only be able to fit a 245/70/17 (Gaining only 1"), i just feel like its not worth it and a waste of $$. Its also a bit late to think about that since i received the kit yesterday
I was under the impression wheel spacers would help the rubbing issue, but it sounds like it will make it worse now?
If i could find someone or a shop out here to do my gears for less than $500, then id be into it, but i only bought the thing for $5K, all ready put $2K into the lift, $1K into Tires, if i add another $1-2K for re gearing, then I'm breaking bank..
