2007 lift recommendation help
Will_K
It became apparent to me that I need to do something about my sagging suspension. I bought my 2007 3+ years ago as a first car for my son, and since then he's proceeded to not yet get his license. In the meantime I've been using it as a backup vehicle while I've had other daily drivers out of service. I didn't really pay much attention, but I've apparently put a few miles on the vehicle.
I bought new tires, and now the inside edge of the front tires have noticeably worn down the tread. Ya see... I put on a set o skid plates, a harbor freight winch and mounting plate plus a brush guard I picked up from a late 90's Cherokee. Apparently, between the springs sagging and the extra weight, I've been driving with my front coils nearly at a state where the coils bind. I noticed this recently when I started thinking to myself "ya know... I don't know how many miles exactly I've put on this thing, but it's been a while - I oughta change the oil. Where's that drain plug at"
So I'd like to be set up with a little bit of lift so it can be used for some off-road stuff. Nothing that drives me into changing more parts, and I'd rather keep it inexpensive... I have a slightly used set of original struts, so if I gotta get out the spring compressor I can handle that just fine. Can I reasonably find something under or around $200? As I mentioned, I've got a lot of other daily driver projects so I don't want this to turn into a $500 or $1000 project, but at this point it's become apparent it's not really something I can put off...
H&R springs are reasonably priced and good quality, check all the ball joints and bushes while it's in bits and it will need an alignment once you've finished.
Honestly, the stock suspension is trash - I took mine off at 79k miles back in 2010 when the KJ was 5 years old, I can't imagine how it'd be now especially with the extra weight of the winch thrown in. It was already sagged 1.5" at that point. OME will make you love the KJ - still one of the best riding/handing vehicles I've driven, and for probably $1500 all in (lift and new UCAs), it'll handle on and off road amazing.
But for $200? I don't know where I'd start. Probably at a bare minimum get new stock springs and shocks, but you'll still won't even be at new stock height because of the weight of the winch. You maybe could only do it up front and leave the rear with spacers, but then you'll have a loose rear with a relatively stiffer front which doesn't help with articulation. Adding spacers will only preload it more and wear stuff out more, and ride even worse, you'll be back to this spot in 10k miles or less. Only way out is stiffer springs. I'd probably just take the winch and brush guard off to save weight (maybe get a receiver for the front and stick the winch in only when you need it).
Will_K
The diesel coils have a touch more beef to them. That's what I put in.
Actually that's a solid point with respect to trying to do this on the cheap. One of the local yards has. Crd vehicle even.
u2slow
BC
Even new (rockauto) they didn't cost that much.
Old CRD springs will be dead, they were under rated for the weight of the diesel, mine had sagged so much it was almost on the bumpstops all the time at 140,000 miles. A new set would be good on a light V6 and you could grab the rear upper isolators from the yard to add to the rear end so it matches the front.
