2006 LIBERTY
Irish429
Montrose, CO
In reading abo0ut cooling issues on the 2006 Liberty there is mention of a bleed screw.
WHERE is this located? I can'[t find anything about it in my manual.
Thank you.
GitEmSteveDave
Howell
Should be right next to the alternator where the upper radiator hose comes in. Not sure what size bit you will need for it.
Spray penetrating oil first let it sit in a while.
it can be in there tight! You don't want to strip it. Counter clockwise to loosen.
Apply downward pressure using longer handle ratchet, keep it Vertical, then to break it free.
A coolant pressure test is best, if you think you may have a leak or air entering system.
