2005 body yaw when applying and lifting throttle - fix & stay OEM or not with fix?
MachSilver08
Austin, TX
All,
Our (bone stock) '05 Liberty Limited 2wd has an issue where the body sways left/right depending on whether the gas is being applied or not. I've google'd like crazy on this and it sounds as if a rear or upper control arm could be the culprit. I don't really want to deal with, or have the tools to, replacing bushings so I'm looking at buying the entire assemblies.
If others have had this same issue and it wasn't one of the control arms I'm all ears!
Anyhow, any input from you folks on whether I should stay with Mopar OEM parts on this or whether other options (less $) are of similar quality, like Mevotech?
Thanks in advance for your input.
Phil + Neela
Vancouver, WA
How much does it sway?
The first thing I would check would be your swaybar linkages. They're generally cheap and easy to fix anyway. Usually when they're broken, it's diagnosed when going over speed bumps or turning corners though. Do you get a lot of body roll with those actions too?
Check the simple things first, then we'll build to the more expensive/complicated :gr_grin:
MachSilver08
Austin, TX
It sways a lot, feels like a big wind gust hitting the car when you hit or let off the gas. Bumps and turns don't appear to be an issue.
rear lower control arms more than likely, that will make it do what you are describing. Don't go aftermarket, I had to use some in a pinch and tore them up in less than two months
JeepKj03
Oakland, MI
I had the same issue, it is the track bars. I replaced mine with bushings from rockauto and have not had a problem and that has been just about 2 years now. The only problem is you need a hydraulic press to get them out. I believe you can buy the whole bar.
MachSilver08
Austin, TX
Thanks!
JeepKj03
Oakland, MI
Just a reminder if you do replace them you’re self. Make sure you tighten the bolts when the vehicle is on the ground. This will place the bushing in a neutral state and will keep them from tearing.
MachSilver08
Austin, TX
Yeah, noticed that in the manual. First car I've ever seen that requires that. What a PITA.....
Thanks
J-Thompson
just south of doucheville
Wow
I never realized that was how the LCA bushing
was designed ,kind of weak
I have been running Rustys Off Road adjustable LCA's
for 5+ years front and rear on the TJ with no issues
They are BEEFY and come with a very stout oem style
rubber bushing that is cheep and easy to replace
only draw back I found is after you adjust them a quick
tack weld on each jam nut is needed
Bingo....failed bushing. Failed lower bushing shown on the left. Easier to replace arms than I expected. Wrestling the exhaust was a bit of a pain but that was the worst part.
Anyone want to buy old ones for cheap that can be rebuilt?
Yes thats how all of mine have looked figured thats what it was
Porkchop
Troy Mi
So when doing a lift loosen them up install lift put back on ground and retighten arms.
Humm maybe add this to lift how to with why for people who dont know to do this when adding a lift.
