1.25" adapters on unlifted KJ
barca64
St. Augustine, FL
Hello. I want to add wheel adapters to my 05 Liberty so I can put 5 x 5 lug pattern rims on the 5 x 4.5 wheel studs. It seems the 1.25" spacer adapters are the standard, however my jeep is not lifted.
Will the extra 1.25" of spacing cause any problems on my Jeep??
Any advice helps. Thanks.
Going to be some issues with rubbing
First with sag you have ( assuming since it is a KJ )
Then adding spacers bring the wheel further out into the wheelwell
so will hit front and rear both in the front wheelwells
Even when new that setup would cause some extra rub depending of course of choice of tires
dude1116
Pompton Plains, NJ
Rim backspacing is a big factor too. Depends on what type of rim you're getting
M38 Bob
Arkansas
For what any decent (still POS) adapter set will cost, simply invest in proper wheels.
RIGHT ON !!! :icon_lol:
These people installing " so called cheap JK wheels" still forking out 200 for a good set of spacers , just missed a set of Moabs for 125 for all 5
mx3_ryder
troy VT
Boy, I'd sure love to find a full set of moabs for $125.
Even $125 on top of that $200 for spacers wouldn't be realestic for a set of 5 moabs from the prices I've seen lately.
M38 Bob
Arkansas
Tom, I'm SURE it's just a coincidence that every member here and on any other automotive forum with any real tire shop/suspension experience would rather have a case of the clap than a set of spacers.:manos:
CactusJacked
Chicago Suburbs
I put spacer adapters on mine years ago, only because I wanted to keep my color matching Renegade wheels. However, I used good billet hub-centric adapters, not cheap POS ones, nor the kind that gives one the clap! ;)
Oh not these right?
I know
