1"-1.5" lift coils?
Any OME coils are only 1.5" lift coils,they have light(350lbs,OEM rated),medium(375lbs),HD(400lbs),and the CRD(500lbs) coils,of course the HD and CRD coils will give more lift due to being stiffer.
protek yer neck
Northern Ontario
spring(the season) has been rough on my coils, I lost about 1.5" in the front and 1" in the rear. I plan on removing the washers and adding slight lift coils(1.5") with a softer spring rate witch I think will level out, not a lift but back to what I had with softer ride.
your thoughts tjkj2002? as you are always helpfull thx
Go with the OME meduims or HD's,I would recommend the HD myself,they won't sag and still give a good ride if used with Rancho or OME front struts and rear shocks,I prefer the Rancho's myself plus they are a little cheaper.The front Ranchos are part# 17505 and the rear Rancho shocks are 17004's(made for a stock hieght Durango).
