Liber
- Joined
- Mar 7, 2006
- Messages
- 57
- Reaction score
- 0
Check this out,
http://cgi.ebay.com/ebaymotors/02-0...33597QQitemZ8049095622QQrdZ1QQsspagenameZWDVW
Just found this on ebay. Sounds good and all but I'm not falling for face value advertising. Has anyone used or heard of usage of these chips. If so do they actually work with out f-ing up your car royaly?
incase you are checking this post after the ebay bid closed here is what is said with out the pictures
This particular Advanced Timing Performance Chip uses a special resistance value of 200 Ohms to alter
the ECU Sensor and signal the computer that it's receiving cold air at the most optimal
temperature of 60 Degrees.
The Advanced Timing Performance Chip eliminates the costly parts and even more costly installation of ECU components (many other mods such as the ones made by JET require soldering and modifying the main board) which only skilled professionals can do. The Advanced Timing Performance Chip provides the same end results and the same reliability of these kits but in a do-it-yourself application. There is no risk of engine or electrical system damage since the modified sensor signal will always remain in the same specified range as recommended by the manufacture. Our Performance module work's in conjunction with your Liberty's ECU and will not affect engine reliability or fuel economy!
By using The Advanced Timing Performance Chip, your Jeep Liberty's ECU will receive slightly adjusted ratios which make your vehicle think its taking in more cold air, which in turn will cause the Air/Fuel ratios to be slightly adjusted to offer more performance & increased horsepower. This is the same concept that the ECU components do but at a fraction of the price!
Installation of our Performance Enhancer into your vehicle is very easy and requires no special tools. We provide step-by-step instructions with the modules, and also will have customer support available at any time via [email protected]
Our Upgrade can be easily installed by anyone, from a novice to a professional mechanic in minutes!
