03 jeep liberty speaker upgrade
inuk5huk
Canada
Hi everyone,
I am looking to upgrade my sound system in my 03 jeep liberty. I'm looking to replace the factory speakers with some aftermarket speakers. Is there anything in particular I have to look out for when buying the speakers dimention wise? I do believe that the factory speakers are 6'5 inches. What about the depth? Any help would be appreciated.
Thanks.!
Clyde Frog
Central Mass
If I recall from an old thread, someone did report that a set of speakers they got were too deep for the speaker space. Also, some have reported needing to slightly modify the opening while others have not. So those are two things you may run into.
neverenuffbass
Greenwich, CT
I believe mounting depth on the front doors is 2.5" on Libertys and 3" in the rear. You can always make spacer rings if the speakers you want are too deep. Here are 1/2" adapters I made
inuk5huk
Canada
thanks for the replies! now that I have thought about it more, and seeing that only one of my speakers is "crackling", I plan on just replacing that one with the factory speaker. With that being said, in the meantime I am looking to buy a MTX JH202 Amp and a decent Sub. Will the sound still be alright with the stock speakers ?
neverenuffbass
Greenwich, CT
I upgrade factory sound all the time by adding an amp & sub. 90% of the time they are back soon after for a speaker upgrade. I think you'd be much happier changing both
hyde
Factory speakers cost too much. Any regular aftermarket speaker will fit in Jeeps opening. You can also go enter jeep's info over at crutchfield and see which ones fit and just buy and replace them.
If you have premium setup you have to do a little more homework.
Atrus
Metro Detroit, MI
Going to piggyback on this thread as it may help others...
I currently have a 10" sub in a sealed box with a small amp. I'm also runnning a JVC head unit. I am considering ditching the sub and amp in the interest of cargo room.
I'd actually say the stock (non-premium) setup is tolerable in this state, and it's not TOO bad when I run it sub-less...I would like to squeak a little more high volume bass out of the speakers, which seem to start "fuzzing out" a little premature for my taste.
Are there any good suggestions for a reasonable set of speakers that would handle a non-amp setup better than the OEM's? Is this a completely fruitless endeavor? I don't want to add an amp to them...that just takes up space and defeats the purpose of the exercise...I'd just leave it as-is (amp/sub) in that case as I am happy enough with that setup's sound quality.
