Yet more questions on lifts
huntinhick
union, wa
Hello all,
I picked up a 05 CRD last year and I am thinking about putting an OME CRD spring lift on it. first is that a good lift for this ride? second and I going to lose any of my towing ability by lifting my jeep? also I know the CRD is heavy, but will I be able to use a bumper like the monitor lizard with a winch and skid plates with out killing my lift? oh and if it sounds like I have no clue about lifts you would be right. this is the first one I have had worth putting the money into.
thanks
carl
Yes OME full sprung lift is the best ( if not the best then one of two ) out there for your CRD ( 790 and 948 springs, With the CRD the OME shocks seem to be better than anything else
No you can still tow the same
Yes you can add an aftermarket bumper with those
stock CRD springs are rated at 410 lb for the fronts
OME 790s are rated at 500 so you'll be good to go
