Yet another code
libertyman
Man this is a bad month for my liberty I got another code today on the way home from 0455 (A large leak in the Evap system)?, any ideas where I should start looking?
gas cap..
If its not that, there is some hoses infront of the gas tank that dry rot and need replacing. its probably nothing major..
libertyman
Thank god, I well crawl under after work tuesday and take a look, I will post the results
Prest989
Apex, NC
If all else fails, the dealership can fix it for under a hundred bucks. They have a machine that does something that apparantly tells them where the leak is.... unless the mechanic lied, which would'nt surprise me.
There is a green cap in the engine aby where they put dye(smoke I believe) into the system.
2003KJ
gas cap..
Usually, and i emphasize usually when the gas cap isn't tight, or "wears out", it will throw a code for a small evap leak......but like I said, that's usually, and still warrants checking.
