Window problem
Kjreny03
Port lavaca
My front passanger window has come out of it track. The casing that holds the tread in has a hole so now when I try to roll it down the tread comes up through my door weather stripping. How do I fix this? Jeep wants $300 to repair it.
trent.brown
Fort Benning, Georgia
I hope you got this fixed already. Mine did the same thing on the passenger front. The tube that holds the worm gear is broken. I tried many different fixes from glue and tape, to a coupling designed for pvc pipes, then coupling and glue. I ended up replacing the entire regulator with one i bought at advance autoparts. If I remember correctly, it only cost about $80.
Its a very simple fix.
Remove Interior door panel. 2 screws (one in door handle and one in door pull hand grip) then it pops off if you pry with a screwdriver starting at the bottom near the speaker.
Remove plastic weather liner. Its held on by a tarry black substance that is reusable. Just peel carefully around the edges.
Remove speaker. four screws.
Disconnect window. Pry two c clips out from the sides of the window. pop the window away from you, raise it, and tape it open.
Remove the window regulator. six bolts (2 top of track, 1 bottom of track, 3 on motor) Squeeze the hole contraption through the hole in the door.
Installation is reverse of removal.
Good luck.
martin_metal_88
Quebec,Canada
Window problem are pretty common on our baby. Just replace the regulator with a new one or a used one. Maybe give a look at the other one and see if they might need replacement while you are working on it.
Over here in the forever expensive Quebec they are between 0 ( used ) to 200 from Jeep new so shouldn't be to expensive.
djta11
Louisville, KY
My tread began coming up through the base, too.
I got a slightly larger diameter tube about 2-3" long and slit it length-wise and placed it over the break in the factory tubing. I then used a butt load of zip ties to tighten everything down.
So far, so good except when I use the "auto down" function on the switch. If I do, it'll pop right through and I've gotta start all over again.
I'll eventually replace the entire thing but at this point, I was getting too antsy for a lift so the window regulator is sitting on the back burner.
