WILL The wheels work?
nwguy
Michigan
Have a 2006 Liberty that I change the tires back and forth for winter. Found a guy who is parting out his 2000 Grand Cherokee and the 16 inch wheels.
Will the Grand Cherokee wheels work with the Liberty?
thanks
1BADKJ
Barnegat NJ
Will not work. Like he said they are 5 on 5. Liberty is 5 on 4.5. 1998 and older grandcherokee wheels will fit. But even then they are all 15" rims
02 Salsa
Willoughby
Wrangler wheels
Will 2013 17" Wrangler wheels fit a 2002 Liberty? They have the stock 255/75/17 tires, but I can replace them.
JEEP BOLT / LUG PATTERN
JEEP MODEL YEAR O.E.M
WHEEL SIZE LUG PATTERN
METRIC LUG PATTERN
INCHES STUD SIZE HUB/CENTER
BORE OFFSET
CJ5, CJ7, CJ8 55-86 15x6 5x139.7mm 5x5.5in 1/2-RH 108 L
Cherokee, Grand Wagoneer 6 Lug 74-92 15x6 6x139.7mm 6x5.5in 7/16-RH 108 L
Cherokee XJ 81-01 15x6 5x114.3mm 5x4.5in 1/2-RH 71.5 M
Comamche, Chief 80-93 15x6 5X114.3mm 5x4.5in 1/2-RH 71.5 M/H
Commander 06-UP 17"-18" 5x127mm 5x5in 1/2x20 71.5 M/H
Compass 07-UP 17"-18" 5x114.3mm 5x4.5in 12x1.5 67.1 H
Grand Cherokee 93-98 15x7 5x114.3mm 5x4.5in 1/2-RH 71.5 M/H
Grand Cherokee 99-UP 16"-20" 5x127mm 5x5in 1/2x20 71.5 H
Liberty 02-UP 16"-18" 5x114.3mm 5x4.5in 1/2x20 71.5 M/H
Patriot 07-UP 16"-17" 5x114.3mm 5x4.5in 12x1.5 67.1 H
Wrangler YJ, TJ 80-06 15"-16" 5x114.3mm 5x4.5in 1/2x20 71.5 M
Wrangler JK 07-UP 17"&18" 5x127mm 5x5in 1/2x20 71.5 M/H
1BADKJ
Barnegat NJ
There ya go. 200.00 worth of spider trax spacers will make them fit your jeep. And make your stance 2.5" wider.
