will abs wires reach on a lifted 06?
new jeep owner
New Brunswick Canada
I see a lot of people (on here) with 06 and newer liberty's that are lifted.
I understand the brake lines have to be relocated, but what about the wires for the abs? do they have to be extended? since there is one at each wheel.
Cardhu
Great White North
Take a good look when putting in your rear springs. you should be fine as in my case the brake lines are the shortest part when fully flexed out. I still have my rear sway bar so even when rear is under full extension it will not pull anything.
I did have to remove a clip attached to the brake hose but it will be obvious when you do yours and you flex out the rear to put in the springs.
If there are any 06 or 07 without the rear sway bar they may have a different experience.
new jeep owner
really appreciate the input guy's
I've had the liberty almost two years now and hope to have it lifted by this fall.
I've been gathering knowledge from here, and trying to save the money to do it right the first time.
guess I'll just have to bite the bullet and git er done.
