Which OME to use with ARB and winch?
tboneil24
Chicago
I couldn't find this info on this forum and was wondering if I should use the CRD heavy duty springs(my libby is gas)? ARB is going on right away and then a winch soon after. I might try to put both on at the same time, as that makes more sense. I will also be towing this vehicle, 4 down, quite often.
J-Thompson
just south of doucheville
for this I would probably go CRD
just my .02 worth
I ran an ARB with 927s for 100,000 miles, it did sag about 3/4 of an inch, switched those out for 790s and have 30,000 on them, ride is great and holding up great
Even with only a 75 lb push bar & skids up front, I have lost some height up front pretty quick with the 927's. The ride is fairly soft up front, but that may be due to the valving of the Bilstien's.
I had considered a Warn winch up front, but based on the current springs, I feel that 790's would be a requirement with winch.
