Where to stop
Toy KJ
Hey Tom for some reason I posted to myself,I don’t want to run into the problem you said other than the parts I have what else do I need I only want about 3 inches and tires not to rub
3 inches of lift ?
Then 927/948 combo with a 1/4 inch top plate in front and one extra upper iso each side in the rear
What size tires?
Toy KJ
3 inches of lift ?
What size tires?
3 inches of lift ?
Toy KJ
3 inches of lift ?
What size tires?
Toy KJ
3 inches of lift ?
What size tires?
3 inches of lift ?
What size tires?
tire size ok
can't read backspacing on wheels but hopefully 7 inches wide and 4 inches of backspacing
17x7.5 +4074.10
If that is close to 4 inches ( 4074.10 does not make sense to me )
7.5 inches will stick out past the flare a bit and you may have to run extra bumpstop in the rear ( tire/wheel may not stuff fully )
Toy KJ
Bump stops and 1 puck? And that is what the paper says on back space, I’ll look into it more and get back to you in a bit also thank you so much for all the help
Toy KJ
Toy KJ
What size bump stops ? I know I’m bothering you with these dumb questions I have 2 Corvettes My mother passed away and this is a tribute vehicle I just want to be perfect
NO DUMB QUESTIONS , maybe dumb answers LOL
Tearflex bumpstops in front of course
in rear 2 hockey pucks per side bolted down to the lower spring perch per side
Have you tried these wheels yet ?
a 7,5 inch wheel with +40 backspacing comes out to 5.82 backspacing
stock is 5 inches , so if above is correct wheel will not fit
Any way to make this fit?
If my computer figured this right you would need at least an inch wide wheel spacer to be almost stock
so 1.5 inches would work
Do you already have these or can you exchange ?
Toy KJ
Delivery tomorrow I told them 2002 with 3 in lift and they said fits so far nothing but wrong stuff please help me I just want it to work, and what to order
