wheel spacers and tire sizes
mtbskierkj
new york
I have a 2007 jeep liberty all stock and i wanted to start to do some work on it but a lift is to much at the moment but i wanted to know if wheel spacers affect anything with clearence with wider tires on them such as rubbing on the fender and a good size of either just tire or good size spacer with a good size tire
Yes you will more than likely rub on the pinch weld and fender/bumper with spacers, go to a 245-70 on stock wheels and be done!:D
sevenhelmet
Ridgecrest, CA
Or get some new rims. My Cragar soft-8s stick out 1.5" farther than stock, which gives the KJ a beefier appearance, IMHO (and I have bigger tires.) You can do this with with up to 245-70 tires and have minimal to no rubbing on a stock suspension. You could even run the soft-8s (or similar) with stock tires for a while if you're looking to save a little cash.
I would not recommend wheel spacers. They're illegal in some states, and some types have been known to fail catastrophically, especially the slip-on type.
Saltydog
I know this will raise some controversy but...
I'm not for wheel spacers on a vehicle that goes highway speeds, a rockcrawler, ect.. then they are fine. The spacers create a weak link that could fail, and a failure in a wheel space could be of epic proportions. Just do a bit of research before using them and hauling your family around in the truck with them installed.
ptsb5a
Northern Alberta, Canada
No controversy here, just a cautionary tale of woe..... good advice too. Consult LEOs before putting spacers on.
LibertyFever
New Brunswick, Canada
I have to agree too. I have spacers on my YJ so I can run with stock 15" wheels but it's meant for the trails only, not highway driving or daily driving.
I could be wrong but I believe most people run with 245/75R16 tires on stock rims on their Libby's. The only reason for using spacers or backspaced rims on a Libby is if you're going to run on 15" rims.
Also when you look at the cost of a set of stock rims and spacers you could easily buy a set of backspaced rims.
