wheel size suggestions
colorado76
Rocky Mountain High
Like 245 or 265 x 70 or 75. But 265 will rub on the pinch weld, but so can the 245 if it's an MT tire.( All you can do is just try it and see.)
0240kliberty
Baltimore md
I was thinking about a all terrain tire as I will probly not four week much but your think a 245 75 would be best to avoid rubbing?
0240kliberty
Baltimore md
Ok thats easy enough really probly a little cheaper too, thank you! Also if it matters I have different wheels 16x8 with a 5 back spacing
Anything over a 245-75 you'll be looking at re-gearing anyways so unless you want to go that route 245-75 or 265-70s about it.
DJSKJ
California
True dat! Even with the 245/75 I am running thinking about re-gearing. However, no rubbing.
DJ
ridenby
Gold Supporter
Kentucky
Just a note: Changed from 15x8 wheel to 15x7,surprising the difference for the better. Running 31-11.50-15 Super Swampers.
