whats the difference?
jeeper4life
Fort Wayne
I have changed every fluid on my KJ except the ****** fluid. My question is, whats the difference between a ****** flush and fill and just droping the pan, and changing it that way? or is it the same?
Vtolds
Stowe, VT
I am no expert, but from what i have read on here when you just drop the pan and change the filters and fill it up your really only changing about half the fluid.
ptsb5a
Northern Alberta, Canada
If all you do is drop the pan and swap filters, you're only changing out 4 qts of fluid. There is still a pile of it in the torque converter, the cooler and the lines to the cooler and back, plus whatever remains in the valvebody. A full on flush and fill is about 8 qts. Thats for the 42rle, the 45rle needs about 13.5qts when empty.
Theres some guys who think you can get away with swapping out a couple of quarts at a time through the dipstick, don't waste your time.
J-Thompson
just south of doucheville
flush and fill = sucking out all the old and filling with new ,several quarts
dropping the pan and changing the filter will only change 3-4 quarts ,IIRC
best to do both
flush and fill first then drop pan and replace filter
or
while pan is down install drain plug in pan
every oil change also drain and fill trans pan
over time you will change out the dirty fluid with fresh and change the filter ever 36K
jeeper4life
Fort Wayne
How would a home do it yourself'er do a flush and fill? also how strong or the ******'s they put in the KJs? Are they known to have problems? I wish they could of put the AW-4's that they put in the XJs in these things...
jeeper4life
Fort Wayne
lol I guess my question is, how do you get that excess fluid out of the lines because just pulling the pan isn't gonna get it out right?
J-Thompson
you could
pull the return line off ,rubber end
put it into a 5 gallon bucket
have a buddy get in Jeep and turn the key to on
put trans in Neutral
then while watching the line have him start the engine ,HOLD THE LINE
and presto out with the old ,fast
as soon as it stops coming out turn off the Jeep
fill as normal
JeepINgeek
Silver Supporter
For Twain In Diana
really? is that so ? if thats all it takes i think that 95 and i might need to arrange a local ****** service party...
hmm sounds dirty.. har har har
jeeper4life
Fort Wayne
lol rock on man lets plan it...
On another note does the ****** have its own computer, different from the motor?
Yes, the TCM I think. (****** Control Module)
KJ ******'s are pretty good in general, since you have an 04 you have the 42RLE. Can't say I know of either ****** (45RFE, 02, some 03's) on this board failing.
JeepINgeek
Silver Supporter
For Twain In Diana
you could
fill as normal
So does this really work for a ****** service?
ThunderbirdJunkie
Bronze Supporter
Newport, KY
There have been a few transmissions that have failed, both 45RFEs and 42RLEs.
Simple fact of life...you have 800,000 KJs on the road, bound to have one or two:p
No, as we all know Mass production means all are perfect, require no maintenance, and out last the owner...:p :D
I can't recall anyone on here having to replace one.
ThunderbirdJunkie
Bronze Supporter
Newport, KY
45RFE KJs are the only ones with a separate TCM and ECM.
42RLE (03+) all have a PCM (powertrain control module)
rockymountain
Spencerville, IN
I think TJKJ will chime in, but I don't think it would be safe and you might need 3 people anyway, one pouring in the fresh fluid as you do it. I just don't know about running it dry. On the other hand, if it is safe, let me know when the party is. :)
JeepINgeek
Silver Supporter
For Twain In Diana
i was immed by someone else that told me that this wasnt advisable. but TJKJs opinion on this is definetly welcome.
Boiler
Muncie Indiana
I bought my own fluid, had it flushed, and they charged me $60 for the flushing only. Then I dropped the pan, changed the filter. So it runs me about $150-$200 to do it this way, after considering roughly 20 qts of fluid (don't forget the TC while you're at it.)
To me, that is a lot better than 1) jacking around with it, 2) gambling with your transmission, 3) buying 5 qts every 3,000 miles and trying to change it over time.
My plan is to do the whole process every 30k, and just filter change ever 15 in between. So basically about $100 bucks a year trans service. To do it every oil change will cost that, and you'll still have some of the dirt in there.
$5 a week and you can change all your fluids, with Mobil 1, at the shortest intervals or sooner. Or you can spend 3-4 dollars a week and cut corners with your expensive drivetrain. Not worth it.
