What fittings will I need?
Ry' N Jen
To instal an '02 type radiator with the inernal transmission cooler?
Can I just use a tubing cutter on the existing ****** cooler lines and some new fittings to plumb the ****** cooling lines into the new rad?
I also want to plumb in an auxiliary ****** cooler while I am at it!
I am thinking of a dual circuit cooler so I can also add a power steering cooler.
Seeing that the factory unit bought the farm a while ago!
We would really like to be able to just drive without having to stop every half an hour to let the ****** cool down!
ridenby
Gold Supporter
Kentucky
Thinking just some fittings at the rad. to get couple inches of hard line out to slide a rubber line over,hose clamps and walla.
kskj
Valley Center, Ks
I used a tubing flaring tool when i did mine. But i was told there is not much pressure on the transmission lines.
