What Does Your KJ Look like with XX" Lift and XX/XX/XX Tires?
autoboy454
MASS
I've seen these kinds of threads on other forums and seeing as we are all definitely picture-****** who like to look at other nice KJ's this thread seems perfect.
You should be able to browse through and get a rough idea what XX Lift on XX rims and XX tires will look like on your KJ!
Post your Rig in here in this format
IMAGE HERE (please limit to three per rig)
Lift Particulars
-Springs (Model #)/Spacer (brand)
-Rims (Brand, Diameter, Width, Backspacing)
-Tires (WWW/AAXDD format, Brand)
-Any other mods pertinent to the topic (bumpers, gear, added weight, etc)
Bring on the KJ Picture pr0n!!!
ptsb5a
Northern Alberta, Canada
OK, now for the particulars....
It's a Rusty's spring/shock lift with about 71,000 miles on it. I added a two conduit nut clevis lift after the bumper install because the springs have sagged terribly.
The wheels are Cragar Soft 8's in a 15x8 with 4" of backspacing wearing Goodyear MTs 31x10.5x15.
I've got ALL the skids on it plus Boiler's little rad support to Front Suspension skid filler plate, an ARB Bull bar with a Warn M8000 hiding inside.
I'm at about 21" from hub centre to fender flair.
Good news....
Coming in the mail are a pair of OME790s a pair of OME948s and some Rancho RSX17505. The rear shocks are a year old. They are Skyjacker N8088s. I've also got a pile of rubber bits and bushings coming too.
With the new bits I expect to hit at least 23" hub to flair all around. I kept my old CV shafts after the torn boot incident and they have been machined by a friend of mine. He worked for beer, it's all good. New inner CV boots are in with the pile of rubber bits I ordered.
New pics in May sometime!!
04 KJ
OME 790 front springs, rear OME948s
CUSTOM made top plates out of plastic cutting board, no clevis 23.25 inches
Rancho RSX shocks front and rear
8 inch wide MOAB wheels with 5 inch backspacing
265-75-16 Goodyear DURATRACS
Heavy items ARB bumper, Rock Lizard custom length rock rails, Kilby gas tank skid
before the last lift was installed in the front
jcbll95
JPOTM WINNER
weston wv
02 With a 2.4 4cyl and 5 speed detours backbone and 8k winch
OME927/948 with a .75 rustys front spacer and daystar top plate and bumpstops
245/75/16 Irok NDs
Same wheels and tires but with a 2.5 inch Daystar lift. the ome combo rides soooo much better
Ry' N Jen
These are 245-75-16 Goodyear M/T R Kevlar tires.
Most excellent rubber.
Don't have anything bad to say about them...
But...
Next time around, I'll be buying 265-75-16 Goodyear M/T R Kevlar tires.
And re-gearing to suit!
And most likely a JBA Steel front differential.
long_tall_texan
DFW, TX
Lift Particulars
-Front: DIY Franky - OME 927, Daystar Top Plate, 3/4" Spacer, Bilstein HD Shocks -- 23.75" fender height
-Rear: Stock Springs, Daystar Puck, 1.25" home made puck, KYB Gas-a-just Shocks -- 23.0" fender height
-Rims: Cragar Black D's, 15x7, 4" BS
-Tires 32x11.50 BFG All Terrain TA
-Trimmed Front and rear Bumper
And Me compared to stock height.
autoboy454
MASS
i gotta get some recent pictures of my KJ so I can post em up. Also have a set of MANTIRES lined up on some pretty "rockin" rims!
what's the max height recommended before you start ruining cv axles?
You are pretty much safe at 23-23.25
I have had mine higher but there was some binding from the CVs ( was at 24 at the time) I try to keep them at 22.75-23 to be on the safe side
kj924
Prince Edward Island,Canada
Here's mine
Lift:
OME 927 Front springs
Rusty's 901 Rear springs
OME Front struts/Rear shocks
3 Ring Clevis
Tire/Rims: 31x10.5x15 Dayton Timberline MT
Cragar 15x8 Soft 8's with 4" Backspacing
ridenby
Gold Supporter
Kentucky
Franky,Al's Arms,stock wheels,245/75/16 Treadwright.
Ry' N Jen
Here's mine
Lift:
3 Ring Clevis
I like it!
And rockymountain's!
Red with Black, or Red with Grey really works together.
All the other ones here look wicked as well!
ridenby
Gold Supporter
Kentucky
The more I see the 15in wheels with 4in bs the more I like that route,LOTS more tire options,and cheaper.
I like it!
Agreed, I read that you're more likely to make a magazine if you're red....
