Vibration through gear lever......
Banditsteve
North Yorkshire. UK
Hi All,
Just another quick question for you - I was travelling down the motorway last night (dont spend a lot of time on motorways if i can help it) and was doing about 80 mph (To keep up with the traffic flow of course as the limit is 70 over here) and everything was fine, then the traffic flow got a little faster and at about 85 there was a loud "drumming" vibration started which could be heard in the cabin and also felt as quite a severe vibration on the gear lever (Manual gearbox) It continued till about 90 and then I backed off as I realised I couldn't "drive through it. Anybody else had this? New tyres were fitted a couple of years ago so i am thinking it is just the rear wheels need balancing again. Big wheels and lots of rubber will make a lot of vibration if they are out of balance wont they! Fronts out of balance make the steering wheel shake and rears make the whole vehicle shake! The only thing that concerns me is that I had the rear prop shaft off a few weeks ago to lube the splines trying to get rid of a rattle and I am thinking I might have done something wrong. I am pretty sure I must have been doing 85 since but cant remember. I marked the flanges as I took the prop off and pretty sure I got it back in the same place but even if I hadn't it would vibrate before 80 anyway wouldn't it? I value all your comments, Cheers, Steve :D
rockymountain
Spencerville, IN
did it happen all of a sudden or was it gradual with speed increase. Sometimes weights fly off wheels. Weights fly off drive shafts too. If you felt it in the shifter, maybe see if a weight fell off the drive shaft. Any vibe in the steering wheel? can you feel it on the center console? the seat of your pants?
Banditsteve
North Yorkshire. UK
It sort of appears at 85 but not there at 80 and shakes the whole of the jeep in a vibration but nothing through the steering wheel which leads me to think its the rear wheels out of balance. Will get em balanced next time I get some spare time on a weekend. Was just hoping somebody else had had the same issue. Maybe its a speed limiter? :rolleyes: Hehe. Thanks Guys. Steve :D
