Vibration after 2" suspension installation
Chen
Israel
Hello,
Did any of you got vibrations from the front propeller drive shaft die to 2" lift kit ?
I have a Liberty Jeep 2003 3.7 lifted 2" , and from that point there started vibrations at 100 km / h and at 120 km / h it impossible to drive. When I remove the front drive shaft, the drive is smooth and without vibration, does anyone know or experience such a problem?
Thanks
rjkj2005
US
The angle of the front drive shaft doesn't change with a lift. Just time for a rebuild of the shaft.
Sent from my SM-G965U using Tapatalk
Chen
Israel
Parts I've replaced so far:
Front Drive shafrt
Left and right cv axle shafts
Engine mounts
Transmission mount
Left and right wheel hubs
All ball joints
Control arm
And more
Chen
Israel
First of all, thanks for the quick response.
It's strange, I did a test and lowered the transfer bridge by 1 "(with spacers) and the vibration decreased by half and I wonder how it is possible that theoretically you're right but as a fact it affected?
Second, can the new shaft come out of balance?
Thanks
Chen
Thanks
Chen
New shaft could be out of balance or not seated properly
You did not lift it that much, 2 inches is not very much at all
I ran over 4 inches for several years and thousands of miles
Dropping the transfer case causes more issues really
Chen
Israel
Hi,
I am embarrassed to say that I solved the problem with two aluminum bends at a dollar cost (after two years of replacing parts with hundreds of dollars and Israeli shekel in my case), I simply balanced the drive shaft with 2 aluminum bends and the problem was solved, I'll send it to balance in a professional place
Thank you very much for your willingness to help and guidance.
Chen
