JeepLibertyKK
- Joined
- Dec 1, 2013
- Messages
- 42
- Reaction score
- 11
I have a 2012 JEEP LIBERTY SPORT 4X4 with the following:
COMMAND TRAC II - PART TIME 4WD
DANA 30/186MM FRONT AXLE
FOUR WHEEL DRIVE (4WD) (4X4)
3.73 REAR AXLE RATIO
CORPORATE 8.25 REAR AXLE
CONVENTIONAL DIFFERENTIAL REAR AXLE
4-SPD. AUTOMATIC VLP 42RLE TRANS
With approximately 98k miles, I’d like to change out the front axle fluid and would like to verify this would be the correct choice:
Valvoline Daily Protection Gear Oil / API Service GL-5 / 80W-90
FRONT AXLE / SAE 80W-90 Multi-Purpose Type, GL-5 Gear Lubricant or equivalent.
REAR AXLE / SAE 75W-90 Gear Lubricant or equivalent.
Thank-you!
Thank-you!
