Undercoating
mikes07kj
Cincinnati
Has anybody done or though about undercoating their jeep. Not just for mud or water but for the salt and everyday grit on the roads. I always wash mine real good but was thinking about something extra to protect against rust.
I got the cans of undercoating when I bought mine and did everything I could see and spray into
offrovering
oh
Had mine professionally done at delivery new from factory. Now I just touch up and hit spots with the cans of 3M.
If you have rust already you need to wire brush and clean it all, then coat it. Its a great thing to do in the summer or early fall, but at this point it may be too late for the year.
ShafferNY
Ticonderoga, NY
Years ago vehicles used to come from the factory undercoated. They don't anymore. I don't know why.
On one autobody forum I was surfing I read that manufactures stopped doing it because it was just trapping in moisture and causing premature rust out.
My is undercoated,I'm from South Dakota and all new vehicles must be undercoated before leaving the dealership.I actually undercoated my own KJ since I pulled it of the transport and did the dealer prep package before I thought about buying it.Most dealers back home charge about $120 to undercoat,it's not the cheap stuff that you buy in rattle can either and is sprayed on much,much thicker.
Just a cost issue,undercoating stops corrosion if applied to a rust free surface.
offrovering
oh
The best thing is to get a full winter service, they undercoat and also apply application inside doors and frame rails.
Again, only really does anything to a rust free surface, so if you have rust you have a lot of work to do first. Of course, if you are in a heavy salt area, something is better than nothing
blue_kjR417
Platinum Renegade
Jonesboro, AR
I bought my jeep oct 08 and I think mine might be undercoated, but a lady had it before me she was a nurse. I seriously doubt she had it done but idk, like the only things that seem to be coated are like the frame and the underbody nothing on parts like the skids ****** tcase or anything like that idk why or how it was done but theres no rust so...
The skids,axles,trans,and such should not be undercoated,only the underside of the unibody only.
mikes07kj
Cincinnati
Rust is not an issue and I want to keep it that way. Whats a good brand to buy as far as undercoating products. I know the guys up the street at dunlops so I can use a bay and get my car up on a lift, will make it a lot easier to do.
Did I say car I meant jeep.
I used QuakerState undercoating,though you need a special applicator gun and buy the stuff in 30 gallon drums only.
Otherwise use 3M's rubberized undercoating,you will need about 10-12 cans at least and will need to touchup often(best out there for private use but not near the quality as industrial stuff).Do not coat the engine,trans,t-case,axles,any suspension parts,bushings,driveshafts,CV shafts,exhaust,and any exposed bolt threads.
