U-Joint question
sport
Delaware
Does anyone have any experience with replacing u-joints on the Liberty?
sport
Delaware
You all know there are 2 u-joints on a KJ right? If you want to get technical there are 4 u-joints right from the factory.
I thought only 2 on the rear shaft, are there u-joints on the front shaft as well? I thought people were starting to do u-joint conversions on the front?
Nope,not on the front driveshaft,look closely under the hood and you will find the other 2 u-joints(hint look at the lower drivers side front area).
Idaho08KK
Idaho
Well the other two would be in the steering shaft down to the rack. Did I win a prize??:D:D
Powerslave
Pittsburgh - Come & Get Me!
Section 3-9 of the 2006 FSM shows the U-Joints on the rear propeller shaft... The front shaft joints are covered with rubber boots, and are being called CV joints, not U-Joints. This is for the 2006 so, it may be different for older models?
The other 2 u-joints are the 2 on the steering shaft,same for all years of KJ's.
Ok so I woulda sworn up and down that there was only 2....the ones on the main driveshaft......errrr propeller shaft per the FSM. So I woulda been wrong.
I even replaced a rear universal once on a truck I had and the replacement even had a zerk in it.........wow, the old days of zerks and manual locking hubs.
Powerslave
U-joints on the steering shaft, sure, but the poster was referring to drive-line shafts right? For which there are only two, on the main drive shaft, the front is CV Joints. The poster wants to know how hard it is to replace the U-joints, well, I would have concluded he only meant drive-shaft ones.
sport
Delaware
Thanks man, I was referring to the driveshaft. I did replace the U-joint over the weekend and wow, what a difference. No more vibes.
Powerslave
SO, how hard are they to replace? I was looking at the FSM, and it looks like it's easier than on older vehicles. They pop out once you remove the cap? Then put the new ones in, and put the caps back on?
sport
Delaware
That is basically how you do it. remove the pins wack one side out to free the cap then same on other side to free from Yoke then do same on driveshaft side.
Here is a how to I found..BTW I really didn't know what a U joint was till about 2 weeks ago! haha
http://www.stu-offroad.com/axle/ujoint2/ujoint-1.htm
