TSB 08-048-05 Differential Mounted Rear Wheel Speed Sensor
Old Navy
SwampEast MO
NUMBER: 08-048-05
GROUP: Electrical
DATE: September 01, 2005
SUBJECT:
Rear Axle Fluid May Contaminate The Differential Mounted Rear Wheel Speed
Sensor
OVERVIEW:
This bulletin involves the replacement of the differential mounted rear
wheel speed sensor
and the replacement of the rear axle fluid.
MODELS:
2005 (KJ) Liberty / Cherokee
SYMPTOM/CONDITION:
The customer may experience a brake/ABS warning light or a Malfunction
Indicator Lamp
(MIL) illumination. On vehicles equipped with an Anti-Lock Brake System
(ABS), a Red
brake light and/or an Amber ABS light may illuminate and remain on. On
vehicles NOT
equipped with ABS, the MIL may illuminate. The MIL may be due to DTC P0501 -
Vehicle
Speed Signal Performance / Vehicle Speed Sensor Plausibility.
The above condition may be due a rear differential mounted rear wheel speed
sensor that
may be contaminated by the rear axle fluid.
DIAGNOSIS:
Using the diagnostic Service Info procedures available on TechCONNECT, if
proper
diagnosis determines that the rear wheel speed sensor requires replacement,
then perform
the Repair Procedure.
PARTS REQUIRED:
Qty. Part No. Description
1 56041393AA Sensor, Wheel Speed (rear)
1 05086373AA O-Ring, Sensor
1 05013477AA Axle RTV
1 04897151AB Brake Parts Cleaner - Non-Chlorinated VOC
Exempt
AR (3) 05010320AA Lubricant, Mopar Synthetic Gear - 75W-90
AR (3) 04874469 Lubricant, Mopar Synthetic Gear & Axle -
75W-140 (if towing)
AR (1) 04318060AB Limited Slip Additive (if Trac-Lok Equipped)
NUMBER: 08-048-05
GROUP: Electrical
REPAIR PROCEDURE:
1. Disconnect and isolate the negative battery cable from the battery.
2. Raise the vehicle on a suitable lift.
3. Remove the rear axle differential housing cover.
4. Thoroughly clean the axle, differential, and differential cover of old
oil, debris, and
RTV.
5. Remove the rear wheel speed sensor electrical connector. Remove the
sensor from
the axle.
6. Install the new O-ring, p/n 05086373AA, to the new rear wheel speed
sensor.
7. Lubricate the new rear wheel speed sensor and O-ring
8. Install the new rear wheel speed sensor, p/n 56041393AA, to the axle.
Tighten the
attaching bolt to 9 Nm (80 in. lbs.).
9. Verify that the seal is securely in place between the sensor and wiring
connector.
Install the sensor electrical connector to the sensor.
10. Apply a bead of Axle RTV sealant, p/n 05013477AA, to the differential
housing cover.
CAUTION: If cover is not installed within 3 to 5 minutes of new RTV sealant
application, the cover must be cleaned and new RTV sealant applied.
Failure to follow instructions will cause a leak.
11. Install the cover and identification tag. Tighten cover bolts in a
criss-cross pattern to 41
Nm (30 ft. lbs.).
12. If not already removed, remove the fill plug.
13. If axle is equipped with a Trac-Lok differential, install 4 oz. of
Limited Slip Additive to
the differential.
14. Fill the axle differential with the correct axle lubricant.
15. Install the fill plug.
16. Verify that the rear wheel speed sensor and differential housing cover
is correctly
installed.
17. Lower vehicle.
18. Connect the negative battery cable to the battery. Set the clock to the
correct time.
POLICY:
Reimbursable within the provisions of the warranty.
TIME ALLOWANCE:
Labor Operation
No:
Description Amount
08-19-15-90 Sensor, Differential Mounted Rear Wheel Speed -
Replace
and Rear Axle Fluid - Replace
0.6 Hrs.
FAILURE CODE:
71 Oil Leak
