Transmission Relay always on
mlmentor
US
Hi Guys,
I have this code on my liberty P0891, I've already checked the relay. it seems to work fine.
KEY OFF: got (-) in 86 pin/ KEY ON: got (+) in 86 pin/ KEY START: got (+)
KEY OFF: pin 85
got nothing
KEY ON : pin 85
got nothing
KEY START: pin 85
got (-)
My question is: What did trigger this code on? How it supposed to be normally?
Any advice will be appreciated.
dawid5995
Poland
How do you fix this problem?
I got the same code P0891 in my jeep kj 2003 2.8 110kw 545rfe...
Billwill
White River, South Africa
Welcome!
Download the 2003 Jeep KJ Service Manual Here.
Also download the 2_5 2_8 Export Diesel manuals for other information.
Once you have downloaded the 2003 KJ Service Manual, go to Page 8W-31-2 to see the logic page showing the Transmission Control Relay.
First things to check are:
Fuse #5 30A in fuse box under the hood.
Swap over the Transmission Control Relay with an identical Relay nearby.
Disconnect the battery and re-plug the connector on the TCM several times in case of bad contact.
Re-plug connector #C105 several times...the Wiring Section 8W Index Component Locations will show you where the various Components, Connectors, Grounds etc. are located.
Then you will need a Digital Multimeter to measure the voltages expected on the relay and its outputs as well as the ground for the relay. Bad grounds cause lots of problems!
