OZZYKJ
Hi All,
Apologies if there is a post on this, but I have spent two days trawling google, and although found some threads almost close , none exactly, so I have started this thread.
The transmission cooler hose appears to be leaking where it joins on to the transmission cooler at the bottom of the radiator. I don't think the cooler or actual hose is leaking, just the joint. I see from here;
https://www.partswebsite.com/wyckof...ction=107&catid=33972&subcatid=31883&fl_id=40
That I can buy two new hoses (only available as a pair), and/or a hose connector?...
Does anyone know if I can just replace the connector?? and save myself $300 +
