Transfer Case wobbles violently!
Tarikleesimsek
New York
Hey guys. I need help diagnosing the problem i have, I was guessing it is the rear drive shaft u joint but there's no play or any shake when moving. I went under it and see that whole transfer case wobbles. Does anybody know what the problem is? I am hoping i won't need a new transfer case! :( Here is two videos i have uploaded on youtube. Thanks for the help in advance!
https://www.youtube.com/watch?v=dXeZ3tb1oqc
https://www.youtube.com/watch?v=5CIlAxchCVY
Tarikleesimsek
New York
OK maybe its just me but how do you get the videos to work ?
I don't know why they show like that. I just clicked onto youtube wrap and copied the links. maybe you just have to copy the whole thing and put it into your browser :shrug:
Working now
How long has it been since you changed transfer case fluids?
Looks like its been a while from the condition of the plug
But onto what problems are you having?
Unless I am just still asleep yet not seeing the transfer case move ?? Driveshaft seems to be running smoothly so are you having vibrations on the road/ noise ?
JeepCoMJ
SE WI
New transfer mount and transfer case fluid is all I can suggest. I see no vibration, but those are the main suspects typically
ThunderbirdJunkie
Bronze Supporter
Newport, KY
What exactly is the problem? You're just seeing lash between the gears in the xfer case and the rearend gears.
Was there an actual drivability issue that you saw that drove you (teehee) to check this?
Tarikleesimsek
New York
Thanks for the replies guys. You know when the rotors are warped that the whole front end shakes, I have the exact same problem but the rotors and pads are fairly new. Shaking only stops when i apply gas pedal. when i let go it shakes and also when i apply the brakes.The videos might not do it justice. If you guys think its the transfer case mounts I will change them along with the fluid. I have never changed the fluid yet and I have 90k miles. :( Just hoping there is no major problem with it.
JeepCoMJ
SE WI
did you check your rear brakes and make sure that there is no warpage going on there?
ridenby
Gold Supporter
Kentucky
See no problem,other than remove the FILL plug first to be certain that you can refill after draining fluid. Have you recently done anything with rear drive ass. ? Removed wheels,painted them,brakes,shocks,etc..
Tarikleesimsek
New York
Hello again guys! Well shaking stopped by itself but after a while, i got this fast ticking noise when taking off. It has a slight delay/hesitation when taking off from stop or low speed, I don't feel that jump anymore. It feels like this happens from 1s gear to 2nd. Also this ticking noise gets more violent on reverse. Got a check engine light as well, so i went to autozone and got the codes. P0700-Transaxle control system fault. P1775-Solenoid switch valve stuck in TCC position. What do you guys think? I never did ****** fluid or transfer case fluid change. Last time i checked transmission fluid, it looked clean so i left it alone.
