Transfer case output shaft seal replacement
TayJeep
Indiana
So based on the research I have done it looks like my daughters 2006 Liberty with part time 4WD (not sure of the numeric designation) has a leak at the output shaft seal. The only "how to" doesn't have any pictures or at least won't let me view any. Has anyone done this that can provide some steps with pictures? It does not look very difficult but I would rather have something to refer to if possible. Thanks
TheBlueKJ
South Jersey
I have done it. It really isnt too hard. I dont have any of the pictures since i did it over a year ago. I would recommend a slide hammer to get the old seal out, carefully drill a small hole into the old seal screw in the slide hammer and it will be out in 2 seconds. Also drain the tcase when you do it.
Sent from my iPhone using the power of children's laughter
TheBlueKJ
South Jersey
That looks like the same vid i used when i did the job
TayJeep
Indiana
OK, Thanks. I did see that video but was thinking it was for a Cherokee.... Same basics I guess.
