Transfer box oil seal and oil type, to rear axle.
Cardhu
Great White North
Your transfer case takes ATF 4+ .
Any label as such regardless of brand is licesened and the correct fluid. Its Red.
10 mm hex to open fill plug and check. If its not red it should be. No idea on the seal.
atvuornf
Bristol UK
85k miles, to add I just read the service manual and it mentions different oils for the front and rear differentials 80w-90 front, 75w-140 rear.
Does it really matter if I'm just topping up?
Kaden
Crandon Wi
I thought it was 75w90 for both the front and rear diffs and 75w140 if you haul things a lot
atvuornf
Bristol UK
Yes you are correct, I copied this from the manual.
FRONT AXLE
² 186FIA (Model 30) - Mopart Lubricant 80W-90
REAR AXLE
² 8 1/4 - Mopart Gear Lubricant 75W-90 (Trailer
Towing - Mopart Synthentic Gear Lubricant 75W-140
