trans temp light... another issue after dealer service
kjmman
southern washington
I've had nothing but problems from the dealers careless 100k service and I'm doing all of my own work from now on.
I'm driving up to the mountain to go shooting and hit some trail when the trans temp light comes on. I was on steep paved roads and hadn't hit the logging roads yet. I pull over, turn the jeep off to let it cool down and decide I better not go the rest of the way. It didn't come back on on the way back home.
The dealer did a full transmission service on my 2003 kj sport with 95k miles. I'm wondering if the new fluid is toast at this point and if it was most likely caused by the service they performed a week ago. Never had the issue before... Mother in law owned it since it was new in 03.
Thanks for any input
LibertyFever
New Brunswick, Canada
I've had a lot of experience with transmission overheating with my 04 KJ.
First I have some questions for you kjmman. What options do you have? Do you have the Mopar trailer package and the V6 gas engine? If you do then you have a mechanical clutch rad fan and an electrical rad fan.
On my KJ the electrical rad fan failed. When I was climbing steep hills, in 4WD or pulling a heavy trailer the transmission over temp light would come on. Maybe you're experiencing the same problem.
If you have the 42RLE trans that is pretty normal if you on steep climbs and going rather slow(less then 55mph).There has been a lot of trails runs I've done here in CO that the KJ's with the 42RLE trans would have the over temp light come on just going to the trail head,and yes still on paved roads.It didn't matter if they had HD cooling or not.Those of us with the 45RFE never had any issues with trans over temps.
kjmman
southern washington
No towing package and the 3.7l v6. The fan on the radiator turns... Was it cutting out at a curtain point? I'll look into the rad fan and see if I can find a way to test it. If you have any I put on testing/replacing it let me know. Thanks :)
kjmman
southern washington
That's unfortunate... Definitely have the 42rle :( know if my week old fluid is toast at this point? Right when I noticed the light I pulled over and let it sit for 10 minutes.
Yeah the fluid is toast,flush time(not a drain and fill time).
General rule of thumb graph............
kjmman
southern washington
Think I should hold the dealer accountable since they just flushed it a week ago? Like I said, never happened before this...
:icon_idea: I installed a PML 1.5 quart over stock Trans Pan for the 42RLE do your have the 42RLE or 45RFE? Never had a temp light since. :party52:
Anyways if you have the 42RLE the new aluminum pan will keep things cooler and the extra 1.5 quart of ATF+4 helps!
A drain plug is standard and allows easy drain & refill when u need to. You can also install a trans temp sensor in new pan. Fits above OEM skid plate perfectly.
YourCovers.com 42RLE Transmission Pan
I used a Lubelocker gasket and has been absolutely leak free. Unlike the te OEM pan which was constantly weeping and the main reason (beides heat) I went to the PML.
50093[/ATTACH]"]
How can you? You went past the limits and burned the fluid.It happens and was just dumb luck it happened right after the service.
If that was the 1st service it's to be expected to have issues after with that kind of mileage.The fluid should be flushed no longer then 60k intervals with filter(s) for synthetic(ATF+4).
kjmman
southern washington
50095[/ATTACH]"]
That's awesome, I will definitely buy one as soon as possible. My wife would kill me if I bought it right now though... Within the past two weeks I've bought an ome 2.5 lift, duratracs, paid for the service, and did the back breaks/rotors lol
For off road, I wish there was a switch that would force the electrical fans to stay on high speed, to help keep things cool....(hmm where is the mod for this ?) (disconnect temp sensor wires LOL)
Glad u like the PML...it's COOL..!! er..
I painted mine black..high temp -flat...not gloss..
50097[/ATTACH]"]
PS for everything else there is MasterCard ...and the wife wont know at least for 30 days ! LOL....
LibertyFever
If you're going to replace the oil pan I'd drill out a spot in it for an auxiliary temperature sensor.
The Liberty seems to lack one.
Oh and while you are under your hood have a look at the rad. Mine once got so dirty & plugged with dirt that it was useless.
Once I thoroughly flushed it out all was well.
kjmman
southern washington
I understand, not trying to be unethical about this and blame them if it's not there fault... The 3 issues I had before was there fault and this is just icing on the cake. I can't afford a flush for another 3 weeks to a month... Saved for quite a while to afford the lift/tires/service/brakes.
Yes the rad is definitely important in the overall cooling process. I normally let the dealer use their coolant & trans flush machine and get the job done right. I also last time replaced the thermostat while they were there as well. I requested the coolant be set to handle at cold to -45c and I got it back at -50 ..perfect for Alberta Rocky Mountain winter trips.
PML can machine hole / threads for temp sensor I believe at time of ordering.
kjmman
southern washington
They were going to do a coolant flush... But I have a very small/slow leak and they didn't want to make it worse. Eventually need to get a new one...
Well..with all the work you have been doing...$$ it's one thing at a time.
Hopeful the leak can be addressed soon... you dont want a pressurization problem and everything running too hot...
I am religious about the Hoat flush every 5 years by Dealer. Trans fluid too, every 50k miles here. I do drain the fluid also with the pml pan in between as well.
All I know ever since I bought a jeep, I have never been so broke...and when my credit card bills come in, I cant help but use some bad language. :whip: :icon_lol:
Not sure on the KJ's with the 42RLE but my '02 with the 45RFE when offroad will do 2-3 cycles of going to 219 degrees and the fan kicking on then off at 195 degrees and then the fan stays on 100% of the time after the 2-3 cycle of this till I turn the engine off then it does the cycle again and stays on.
kjmman
southern washington
There is some flexibility in the zones. You should check the fluid on level ground,hot after driving for 20 minutes + and yes Neutral, brake on, wheel blocks would not hurt either.
Does the +4 still look clean nice and bright, no foul smell?
kjmman
southern washington
Clean , bright, and smells horrible... I wouldn't think over filling could cause overheating but I've seem weirder happen. I'll drive it and and look at the gauge when the fluid is heated up all the way.
