jeeptorino68
i got the rubber gasket, and let the trans sit for a couple hours draining fluid before putting the pan and new gasket up. it was still dripping a bit of fluid down and onto the gasket surface, i wiped it up and put the pan/gasket up with high temp orange RTV but it is leaking a bit around the seal. i think the trans fluid that was still draining got past the RTV before it cured and it has a little path there.
id like to try again... what should i use this time? just the rubber gasket and no sealant? how do i get it to stop draining down that edge without letting it sit overnight...
