AtlanticBlue04KJ
- Joined
- Mar 12, 2008
- Messages
- 2
- Reaction score
- 0
I use the KJ to pull a boat. The boat has surge brakes that energize when I stop so they also slide and energize when I go in reverse. Some trucks have a fifth wire to energize a solenoid that bypasses the trailer brakes when you go in reverse to back the boat up. The KJ just has a regular 4 wire flat plug. The boat has 5 wires - the fifth wire used toi energize the bypass solenoid when backing up.... I would like to use a signal from the back up lights to energize the solenoid and release the trailer brakes when backing up. I have looked at a wiring diagram and the KJ uses a transmission switch to energize the back up lights. I did not see a fuse anywhere between the transmission switch and the lights. I am worried that the boat trailer solenoid might create enough current to hurt the transmission switch that energizes the back up lights...What is this switch like? Is it like a little micro switch or is it OK/ Are the contacts big enough to handle more than the lights themselves? Any hints or suggestions appreciated. Thanks.
