I HATE the tpms in my '09 F250
it does not tell you which tire is low
dings every time you start it ,when the light is on
and the 4 times in the past year that the light has come on it was the spare
yes the spare on an F250 ,know where that is? UNDER THE EFFING TRUCK
oh and the factory put the valve stem POINTING UP on the spare
I figured out that I can flip the spare and remount it but still it *****
oh and best part is that the light comes on if the tire drops below 50 psi
I have OBA on the truck so adding air is easy
I am looking for a way to mount the sensors in my air tank so they think that all 5 tires
have 120psi in them and never less than 90
they can not sense over pressure only under
side note '09 VW tells you which tire
and the spare is in the trunk ,very easy to add air
'02 TJ ,who cares
