Tires size
Piotr
Hi again
OME lift done
2790,20009
2948,60069
Arkady upper control arm
Arkady 4 link
4.10 gearing
What tires size will be better for this setup?
245/75/16 or 265/70/16
Thanks
Piotr
Thank You for your help
I have dotz dakar et13 wheels
I’ve checked yours post from past and I can tell You prefer 265/70/16
With et13 and OME lift it will works fine ?
Piotr
I have to learn more about backpacking
I found chart like this
7 inch wheel width - 4 inch backpacking is 0mm 245/75/16
8 inch wheel width - 5 inch backpacking is 12 mm 265/70/16
So I have wheels ET13 positive off Center +13 mm
So I can use both sizes question is from Your experience Guys which one will be better for off road with MT tires
Thanks again
What is the width of your wheels ?
That makes a big difference as far as what fits , with the backspacing you have on them
