tires and more
jrogers
Indiana
Been doing a little reading on here to get the general idea of how things work with the kj's so just bear with me if Im a bit off track. I have a stock 06 kj 65th anniversary edition and plan on doing some slight improvements here and there. I have measured my hub to fender lip at 18.625" front and 18.75" rear. So if Im correct that's .375" sag up front .25' rear which doesn't seem too bad for the year. Would i benefit much from say a 2.5" spacer lift to fit a bit bigger tire or would i just be accelerating the rate at which they sag? Im wanting to go up to a 245-70r16 or maybe a tad bigger to open up more tire choices but do not want them to fit now only to have them start rubbing a few months down the road due to increased sag
CzarKJ
Townsend, MA
Stay away from spacer kits as they will sag your springs and destroy your shocks. (based on accounts from this site and many others) 245-70-16 is ok on stock but you may have to do a clevis lift/and or spacer plate up front to prevent rubbing. I had to do a little plastic molding to get mine to fit when I was stock. I would say save up for the full spring lift with shocks unless your tires are bald.
jrogers
Indiana
What is a good spring and shock lift to look into without going over 2.5"? Im not wanting a massive jacked up rig like Im use to just a good dd that can get me home reliably everyday( i live a good ways out In the sticks with some pretty rough roads) but will allow for a more common tire size than stock
around here 225-75r16 is a very oddball size without ordering. Most common around here are 265's but id doubt they would fit even with a 2.5" lift
jrogers
Indiana
Also what is a clevis lift? I've lifted several vehicles but most were solid front axles with leaves or ttb f250's( i designed a killer 12" lift for those bad boys that works really good)
CzarKJ
Townsend, MA
There are a few options for lifts. Check out the KJ lift kit discussion section and especially this thread.
http://www.jeepkj.com/forum/f203/lift-faq-read-before-asking-questions-47137/
For a clevis lift I will help define it a little better. I have attached a photo. The white arrow indicates the clevis bracket with the bolt in it. To do a clevis lift you add conduit washers (0.375" total) between the bracket and the "strut". This will give about 0.75" of lift in the front.
If anyone else can chime in to verify all my info is correct I would appreciate it. And that's my old setup... I am glad I don't have that anymore haha.
Not correct information sorry but.....
3/8 inch clevis will give you 3/4 inch lift not an inch to get an inch height out of just a clevis you'd have to do 1/2 inch clevis which is not a good idea
To the OP
READ,..........
its all been hashed out before
but go to jeepinbyal
Ironman full spring lift will get you 2.25-2.5 inches of lift over new stock height
OME will do the same
either ride and handle 100 times better than it did new
and 265-75-16s take 4 inches of lift and a regear to 4.10s
CzarKJ
Townsend, MA
Thanks Mudd! I thought it sounded a bit much.
Sent from my iPhone using Peanut Butter
