Tire rubbing on arms
frankinliftliberty
Michigan
Need to figure out what I need to do. I have major rubbing on my arms, I had wheel spacers but that just threw my tire balance way off, I am running stock wheels 17 inch, with 31s, should I get a diff set of wheels? If so what should I be looking for
Ry' N Jen
Why would your wheel spacers cause your tires to be "Way" out of ballance?
The only reason I could see would be because the wheel spacers you are using are not high quality!
I run Spidertrax 1.25 inch wide wheel spacers front and rear and have absolutely ZERO wheel ballance problems what so ever!:confused:
