Mopars-Only
Did you change the belt yourself? If so, did you follow the service manual closely, as in putting the allen wrench in the flex plate, and pinning off the camshafts as the manual says?
I figured drill bits would work fine for the camshaft pinning, but I am not sure. A metric drill bit set would hopefully contain the right size, but then I don't know what that size is yet. Hopefully some of you did it that way and can tell us about it. I note it says remove the power steering pump pulley, how difficult was that?
If you changed your belt out yourself, please post any advice or warnings and so forth, for they would be greatly appreciated.
Mopars-Only
Mopars-Only
