02LibertyLimitedChick said:
Forgive me if this has already been asked (I didn't find it anywhere) but is now a god time to change my timing belt? I have 62,*** miles on the Jeep. I'm thinking this was supposed to be done between 50-60,000 miles? Thanks in advance.
Well unless you have the 4-clinder you don't have a timing belt,you do have a timing chain, 2 to be exact and will last a long time and are a very labor intensive job to replace.If you are referring about the serpitine belt(the one that goes around the A/C,water pump,and alternator) then yes it's probally time to change it.I changed my serp belt at 20,000 miles than threw the old one in the back of the KJ just incase to one under the hood ever failed.If the serp belt breaks you loose everything,power steering,alternator,and the water pump.
