The old switcherooo!
AMPlibby06
Rochester NY/Burlington, VT
I'm very used to the window switches being between the seats, but every single passenger of mine isn't and always locks or unlocks the car. I know that many people enjoy the switches being wired to the center, but I think I would like them better on the door. Does anyone think I can rewire the door locks so that they're in the middle (using the window switches)? and wire the windows so they use the lock switches? OR are the window switches 3 way and the lock switches are 2 way? I thought i'd throw the idea out there.
twack
rochester mn
its possible, not sure how it would work with the door lock button i would just get some switches off ebay for another car or hell maybe you could hack a spare kj one so all the switches look the same
Ry' N Jen
I'm very used to the window switches being between the seats, but every single passenger of mine isn't and always locks or unlocks the car. I know that many people enjoy the switches being wired to the centre, but I think I would like them better on the door. Does anyone think I can rewire the door locks so that they're in the middle (using the window switches)? and wire the windows so they use the lock switches? OR are the window switches 3 way and the lock switches are 2 way? I thought I'd throw the idea out there.
You wouldn't be able to just swap places with the factory power window switches moved to the doors because both front and rear window switches and master window lock out switch is a one piece unit!
So, an after market power window switch would be your only option. You would still need to splice into the front power window wiring circuit and get those wires into the front doors.
Then you would have the original power window switch gear in the stock position and two additional switches mounted on the doors for your windows.
You would probably want to have two extra switches on the drivers door so that you could open both front windows from the drivers seat.
flair1111
usa
ive always wanted 1 extra switch that will open and close all 4 windows at the same time.
TruLiberty
Northern Virginia, US
i dont mind it, makes it easier to open the windows because i tend to lean on the center console and drive mainly with my left. would be interesting to have one switch to do it all tho heh
hyde
Same here, I am glad they put them in the center.
Instead of swapping them with the ones on the doors, I would look into possibilities of getting another switch and tapping to the stock window controls. But yea, that won't make people stop locking and unlocking doors.
