thats it, theres nothing holding it on top???
i looked at mine and found some holes with thread and a nut welded, ill take pics of it.
Also my hubs are splined allready.
I think it may be bolted to the engine cradle...
OMG...who stole your engine skidplate?????????? And I guess WJKJ went to all this trouble lying on his garage floor for...a 4x2 to 4x4 conversion....
Get a wrecked 4x4. Then you have all the parts.
I believe they are optional after '03...so...but you should get one if you ever want to go offroading. Mine has the scars to proove that..
Still less work to start with a four wheel drive vehicle.
I had a friend with a FWD Audi A4 and wanted to convert it to a Quattro...
Better off to start with a Quattro, then start modifying it!
It maybe more practical to do a 4x4 conversion with an SFA....
Just thinking out load...
going to cost even more
still going to need the controls as if it were already 4wd
still going to need the trans stuff
T-case and drive shafts
going to need to then get the front axle
handle the steering issue
fab up control arm mounts and bracing to hold said mounts
control arms
then you need to gear match
and then......
If thats yours you need to check that boot. Looks like the boot is going bad which will allow the joint to go bad.
And I aint cleanin no bodies under body.
control arms
and then......
what steering issue and what control arms mounts, aren't they the same UCA?
not if you go SFA
o ok I thought u were talking if a 4wd conversion, now 2wd to 4wd might be time consuming, not cheap , but not impossible, correct me if I'm wrong,
Yup, the boot right where it exits the tcase. Its the only boot you can see in that pic.
