Suspension Lift / Spacer Combination?
1BADKJ
Barnegat NJ
you cannot run both lift kits. But what you can do. Do a clevis lift in front and add 2 spring isolators in the rear.
TheBlueKJ
South Jersey
What you should do is stop thinking about getting either because they are both terrible ideas. Go with the Ironman/OME setup with either the Ironman, OME, or Bilstein shocks. You'll get a MUCH better ride quality out of these then the ones you have considered, and it will last longer.
what he said ^^^^^^^
and please read through the various posts on here about lifts and what does and doesn't work
