Stucked radiator bleed screw
Jojo
Tried to bleed my radiator on Liberty 3.7 2004. Hexagon bleed but won't budge even after heating it up. I subsequently stripped the darn thing. Have noticed just above at higher point at radiator is a return pipe to filling reservoir. Surely this system could self bleed into the reservoir bottle. Am I wrong.
Welcome to the forum.
Did you completely drain the system or what work has been performed there that requires bleeding the air out?
Allowing the jeep to fully cool down overnight & refilling the reservoir as necessary to the cold line, and then allowing jeep to fully warm up, will get the system pressurized again, as long as there are no leaks.
The Mopar thermostat also has a built in air bleed hole to assist as well.
Only Hoat or Zerex G-05 coolant to be used in the system.
Jojo
Just added extra comments above, working 3 threads here..
Jojo
I fitted a new radiator and thermostat. Blurped the system while filling with coolant till reservoir bottle was at the indicated level.
Hopefully you used a new MOPAR thermostat.
Allow the jeep to fully cool down.
Is it still now at the cold line?
didn't the KK go to an open(?) system where the tank is just an overflow?
just keep topping it up. air should eventually purge out.
Right..Thanks for waking me up! ;) OP has an 04 KJ, just moved into KJ Gen Discussion section, Thanks!
I would like to mention that for those wanting to break free that hex bleeder, please don't use an allan key.
It's on there real tight, and a good way to strip it.
Use a good penetrating fluid first, & system hot.
With left hand on top keeping it straight, w/downward force, and the ratchet to break it free.
