Stock Speaker Wire Identification
Atrus
Metro Detroit, MI
I need some help identifying the speaker wire colors for my 2007 so I can install my amp (using a line level converter). I have the standard radio – single CD player, no satellite radio or anything.
I have the 2006 service manual, and if my memory serves me correctly, it called for Dark Green/Dark Blue & Dark Green & Orange for one rear speaker, and Grey/Dark Blue & Grey/Orange for the other. The switched power wire was supposedly yellow/pink.
I checked the wiring going into the driver rear door, and there were no wires with those colors. Anyone have any idea of what they should be for ‘07? I could probe wires and whatnot, but I’d like to be as unintrusive as possible.
Atrus
Metro Detroit, MI
Oh wow, just had an epiphany here. If anyone has the answer, I'd appreciate it, but I can just look at the pinouts on the harness in the manual and look at the Jeep harness for the matchup.
I was going to run 18 gauge wire, connecting to the stock wiring somewhere in the rockers. I'd run that back to the amp, where I'd have the LLC in close proximity. Seems pointless - I think I should hook up the LLC under the dash when I connect the remote turn on wire and just run an RCA back to the amp. Less connections and less clutter.
razzerx
Chi-Town
Radio wires
Radio C210 Way Cav Circuit Function
1 X40 20gy/wt Audio Mux Right
2 X140 20gy/or Shield
3 X235 20gy Audio Return
4 D25 20wt/vt Pci Bus
5 X112 20dg/gy Ignition Run/acc Signal
5 X112 20lg/gy Ignition Run/acc Signal
6 X41 20dg/wt Audio Mux Left
7 Z515 20bk Ground
8 - -
9 - -
10 X160 20gy/yl Fused B(+)
Radio C122 Way Cav Circuit Function
1 A908 18rd Fused B(+)
2 F982 20pk/yl Fused Ignition Switch Output (run-acc)
3 E2 20or/br Panel Lamps Driver
4 - -
5 - -
6 - -
7 X54 18gy Right Front Speaker (+)
8 X56 18gy/br Right Front Speaker (-)
9 X55 18dg/br Left Front Speaker (-)
10 X53 18dg Left Front Speaker (+)
11 Z514 16bk/lg Ground
12 A908 18rd Fused B(+)
13 A116 20yl/rd Antenna Relay Output
14 D25 20wt/vt Pci Bus
15 - -
16 - -
17 - -
18 X51 18dg/db Left Rear Door Speaker (+)
19 X57 18dg/or Left Rear Door Speaker (-)
20 X58 18gy/or Right Rear Door Speaker (-)
21 X52 18gy/db Right Rear Door Speaker (+)
22 Z514 16bk/lg Ground
hyde
This has gotta go to into electronics FAQ... Good info!
Atrus
Metro Detroit, MI
thanks razzerx, I'll check it out. I think that's what I had from the '06 manual. I don't think mine follows that. I'll check it out tonight or tomorrow morning when my amp install kit/line level converter arrives. I'll check the actual harness on the radio and check the pins per the manual to the actual harness's color and report back for future reference.
Atrus
Metro Detroit, MI
FYI, wiring at the head unit seems to follow this scheme. I could swear at the pillar for the rear driver's door, I didn't find these wires to tap into.
LibertyOrDeath
Kenwood Speakers with Sony Deck.
Thanks for this information. I just wish I thought of using JeepKJ before I started this install. Anyways I got some Kenwood speakers and I currently only have one speaker installed, the left front. For some reason the stock speakers are putting out more bass than the Kenwoods. Anyone know why that is?
