Steering column height locking lever
footfixer
Earth
Searched but didn't find anything.
The lever which locks the height of the steering column (the one on the lower left of the column) no longer has enough friction to hold itself in place for very long -- or over bumpy roads.
I took a quick look underneath and there doesn't appear to be a bolt to tighten. It looks like the assembly is held together by a "rivet".
Anyone familiar with this or experience it? Any fixes, other than a bungee cord? :icon_confused:
Thanks.
Richard
07 liberty
Took mine in to see what dealer could do about it and was told I would need to replace the steering column.
Sent from my Samsung Galaxy s3 using Tapatalk.
footfixer
Earth
Wow!!
Crap engineering at its worst.
Can't say I'm surprised to hear that. There's no way I'm putting a new steering column into my 115K mile 2006 Liberty. Not going to happen.
I'll have to take a really good look at what's going on under there and come up with "something". I bought it new and I'd bet I've adjusted the steering column height no more than ten times.
When the lever is down there is a lot of lateral play. I'm wondering if a couple wraps of thin copper wire around the lever shaft would create enough friction to do the job....?
If I come up with something that works I'll post it.
Thanks for the reply.
eyehatetofu
Buckeye, AZ
I zip tie that sumbitch in place when it starts to act up. It's a real PITA sometimes. Subscribed to see if the new guy comes up with a good fix.
JeepCoMJ
SE WI
I've got a good column that's stripped down to the main shaft without lock tumbler, multi-switch, switches, bag, spring, or wheel. just the main part with what you need to fix the friction plate.
It's not worth much to me, just my time and shipping covered. Maybe you can use parts off of it. It works great and had nothing wrong with the part you're talking about...I just had someone needing the airbag and clockspring.
flair1111
usa
seriously looks like a recall should happen on that. very dangerous.
