Starts to crank, but stops almost as soon as it starts, will not start
homerdo
Perrysburg, OH
2002 Jeep Liberty with 3.7L V6
M issue is that turn the key on and everything works and looks good. As soon as I turn the key to the start position, it tries to crank but ceases to crank almost as soon as it starts.
Did several things to this vehicle today/recnetly before the above issue started.
Today
  • Changed spark plugs
  • Changed coil packs (all 6)
  • Removed throttle body and cleaned
  • Flushed heater core (had a no heat issue)
    Added anti-freeze as it was low and car was overheating last night
Also in the last week, the vehicle has a new battery and alternator.
After I did all the work today, the vehicle started fine and I took it on a 15 minute test drive with no issue. Overheating issue had stopped and vehicle held temperature just fine.
Then went out a few horus later to move car in to garage and I got the "starts to crank but ceases immediately" condition described here. Please help if you can. Could this be a starter issue?
