sicnik said:Has anyone ever used spray-on bed liner on their wheels? I have a set of aluminum wheels I was wanting to paint black. what do you think? Will it hold up on the wheels?
Nick
especko said:I wouldnt use the spray on bedliner, that stuff is pretty thick, and usually heavy, you would probably end up throwing off the balance of the wheels also.
X3-I'd hate to be the person trying to balance those things.SRotblat Posted: Mon Feb 12, 2007 12:10 pm Post subject:
x2, sounds like a really bad idea
tjkj2002 said:X3-I'd hate to be the person trying to balance those things.SRotblat Posted: Mon Feb 12, 2007 12:10 pm Post subject:
I've sprayed bedliners(not line-x or rhinolining,but know poeple that do)when I worked at a bodyshop and there is no such thing as a EVEN coat for bedliners.You can get close and it may look even but it's not and you are going to need major wheel wieghts to correct the inbalance.Personally I will keep moving a tire on a rim till it's balanced with less then 4 oz's(MT/R's are really a pain to balance in the bigger sizes).An EVEN coat of bedliner shouldnt throw the balance off
