so I have them in the back of my truck
any body want them?
like I said these would make a great 5th tire
and I know there are quite a few people running 245/75's brand X but no full size spare
I have a Jeep tire cover that I will through in for $10
I have to check to see if it fits over the 245/75's but it should work
getting a flat on the rear with out a full size spare is the worse
you will have to remove the tire from the front
install the spare on the front
remove the rear flat and install the good front
then get the flat fixed and reinstall it on the front ,which will mess up your rotation pattern
on top of all that you can not use 4wd
now does any body need a spare tire?
