Howdy. I have been coming here fo years but have never registered or posted. The forum here is awesome for finding help on my KJ
Ok. So first off, I own a 2003 Liberty Sport (Freedom pkg. but that is most likely irrelevant). 180K on the ticker and still running good.
just recently replaced the upper and lower ball joints, tie rod ends, sway bar links. Also did the rear upper and outer bushings and bj.
Everything seems ok driving wise, but every now and then when I am turning towards the left and I hit a bump, it sounds like the right front passenger side had a slug put thru it. A hard metalic, sounds like the floorboard got hit sound. The mechanic today said it was the upper ca again, which may be possible. I bought a set from a1auto for cheap. I am thinking it is possible that they could be crap. But I havent replaced the lower ca bushings yet either.
I bounced it and cant hear anything. I shake it I see nothing. I will try getting it up on stands in the next two days for a better check.
He also said my rack mount bushings are bad,which I already knew. I can also feel my brakes bumping even though I have checked and rebuilt everything as needed.
So...are the aftermarket upper ca replacements that bad? Is a set from Jeepinbyal worth it for a daily driver? Can the other things be causing that sound? The bumping brakes caused by sloppy rack? can bad lower ca bushings make that kind of a sound?
my wife drives it on curvy country roads, so....And we love it, so we ain't gettin rid of it.
Anyways, any other ideas helpfull.
